MrsMarriedVoel1's avatar
May 11, 2016
Newbie seeking recommendations
Hello!
My husband, daughter and two dogs are searching for our first Class C RV and I've done enough research to narrow our RV choice to that. I'm feeling stuck about what make/model/year/etc would be the best for us. We plan to use it for shorter vacations but hope to transition to full timing after a year or two(gotta get our ducks in a row before we pack up). Any suggestions are welcome, I just feel stuck in my research at the moment.
Thanks!
  • What is most important is how livable it is for the way you want to use it. That means getting into some RVs and going through the motions of living in it, including storing and getting to all the things you think you need to bring with you, either for vacations or longer times.
    That sort of puts "model" first, but really it is floorplan, and you will find similar arrangements in different models of different makes. What year? Since the basic platforms and construction methods have changed little for 10-20 years, what year will be a matter of budget. If built on Ford E-450 I would probably pay to have chassis 2008 or newer, as I have the 2012 E-350 as a van and like the improvements made since the 2003 model year chassis under my motorhome. If it comes on a Chevy, I'd be looking for 2012 or newer, for the same reason, incremental improvements.
    Floorplan is something only you can figure out. My wife figured it out for us, did a really good job. I would have picked something about 8-10 feet shorter without any closets or cupboards.
    Also consider that needs change with the way you use the RV. If you are really thinking about full timing, consider that you'll eventually be carrying everything you own. That's a different thing from carrying for a couple of weeks or a few months.
