IAMICHABOD
Sep 09, 2014Explorer III
Your experience in a Class C is to be expected,most are on a Ford Chassis and they have a harsher ride than others.
The ones on a Chevy Chassis, like the one in my signature have a much smoother ride and a larger cockpit area affording better comfort.
You might try another Rental company like El Monte RV in your area. They have a more diverse fleet of RVs to rent.
Unlike Cruise America that have only brand of RV made just for them.
Rental RVs are not abused as much as is commonly thought. It is very expensive if you do abuse them. They get better maintenance than most privately owned RV with records to prove it.
Tire pressure will make a great deal of difference in the ride quality on most RVs too.I run the same air pressure as does BuckBarker and the ride is very smooth.
The two clickys in my signature may give you some more insight in your Quest for a better RV experience.
Good Luck.
Good Luck.
38,776 PostsLatest Activity: May 15, 2026
