Jeannie Souza wrote:
Wow... you guys are like mechanical engineers... .. all this information is very helpful.. I did pull out the owners manual last night and read that the battery will not over charge.... and yes... I did pull the plug... then tried lights in the RV.. none would work... hit the switch at the door.. and the lights worked.. hit the switch again.. no lights..then plugged it in...
Gene in NE... interesting .. I had seen these little levels in the RV section of Walmart... so I picked up a package.. and now I know what to do with them.. thanks...
also.. my RV has a leveler ... it's manual... there's a long rod.. like the one used to operate a car jack... and I see where that's used in the front of the RV.. the previous owner pointed it out to me.. but no demo... I did not try to use it...for fear of messing something up... wanted to wait till I get to my friends RV Park .. no doubt Mr. Wonderful can show me how to use it...
Thanks for all your comments... I know just where to come to now when I have a RV issue...
For what it's worth, the "leveler" you mentioned above is actually referred to as a "Stabilizer". Note that it is NOT intended to be used to level the RV. It is used (once you have already leveled the vehicle) to keep the RV from moving around so much while walking around inside the RV. If you crank it pretty tight it will very slightly raise the RV but again, its primary use is to stabilize.
Most Class C's I see in campgrounds do not even use these stabilizers as they can be hard to access, etc. I have never used mine, but I am old and lazy!! They are there if you choose to use them but are not necessary in most cases.
