dennislanier wrote:
For what it's worth, the "leveler" you mentioned above is actually referred to as a "Stabilizer". Note that it is NOT intended to be used to level the RV. It is used (once you have already leveled the vehicle) to keep the RV from moving around so much while walking around inside the RV. If you crank it pretty tight it will very slightly raise the RV but again, its primary use is to stabilize.
Most Class C's I see in campgrounds do not even use these stabilizers as they can be hard to access, etc. I have never used mine, but I am old and lazy!! They are there if you choose to use them but are not necessary in most cases.
Thanks Dennis.. now I know... that's great information... tomorrow I attach the levels in the Walmart parking lot..
