RVER
May 30, 2018Explorer
NEWMAR 2003 gas engine with RPM gauge craziness
I have a 2003 Newmar Mountain Aire Gas with Vortec 8.1 engine and coming home to MA from SC I noticed my RPM gauge would show the correct RPM and then flip up or down kind of crazy. I had another problem so we changed out a positive cable on batteries and it seemed to cure the problem but as we drive further the RPM gauge seems to work and then start flipping out again and then working and flipping out. I also have a ABS light on but brakes check out totally and there is no sound alert to the light just light. NOT sure if it is an electrical problem causing both or just coincidence. Any suggestions? I am having someone check the "Ground cables" to A/C and D/C and see if that has anything to do with it. ANY IDEAS?
