Rick,
You are describing multiple (likely unrelated) issues:
Very hard to believe that the chassis battery is charged when on generator, but not when on shore power. Your converter, charger or inverter/charger really doesn't know the difference between the two sources.
It is not uncommon for the coach maker to wire the coach to charge the house battery bank from the converter, charger or inverter/charger but NOT the chassis battery.
And, as you state, the alternator should charge both banks when the engine is running.
With very low voltage on one bank, be careful about condemning a battery combiner solenoid. If it is powered by the battery with less than 12 VDC, THAT may be the issue.
Clearly, he needs to track down the 5 amp draw. That will take any battery bank down in just a few days.
