Sorry for the confusion... The generator only puts out 115VAC, 60 Hz.  However there is a relay located in the same cabinet and the relay is open.  It has 12VDC on one side and zero volts on the other.  Not sure how this relay is controlled or even if that's the problem.  In my camper I believe the salesman switch only turns off and on the lights in the motor home as long as the switches on the individual lights are on.  I have access to the power distribution center and there is no 12VDC going to the power distribution center.  So, where ever this red wire comes from that is an 12 VDC input to the distribution center, upstream is where the issue is.  I will try to post some links to pictures, but currently have a poor internet connection.
