Had fantastic weekend stay at Bella terra and leaving in morning. Upon arrival here I realized that the 120 electrical plugs (4) were not working in my curbside front slide. The gfci plug is not trip...
Under the slide will be two junction boxes, one is attached to the "main" part of the motor home one to the "Moving" (slide out) portion, between them is flexible cable,, The rest of the house is wired with Romex.. One of those connecitons may be bad That is not the best of connections (Flexible to solid wire) in any case less it is done by a proper electronics technician. which it was not.
