Bfa61's avatar
Bfa61
No 12V power
I have a 2006 Winnebago Voyage 32V on a Workhorse chassis. New auxiliary batteries, new disconnect switch and still no power. I've checked all the fuses, breakers, etc and all good. Everything works when plugged into shoreline. Any suggestions?
NOTE: Did you see the "Announcement : ★★READ BEFORE POSTING HERE★★" located at the top of this forum?
    "Forum Posting Help and Support is reserved for questions on how to post in the forums, signature and photo testing, reporting website or member account issues. Please avoid using Forum Posting Help and Support for RV related questions, as doing so can delay responses to your thread. Instead, create future threads in the RV FORUM which corresponds to the subject of your topic. Thank-you!"
  • Do I understand that you have no 12V power when disconnected but you have full use of all 12V (not 120V) systems when plugged in?
  • Now what fuses are you talking about? My DP has a main fuse located by the main batteries. Not sure if your RV has one.
  • When was the last time you had good power and what did you change to make it go away?
  • Suggest you Google auto reset circuit breaker - doesn't really look like std breaker or fuse but most RV's have them usually located near the batteries. When they go toes up they essentially take the batteries "off line" which in most rigs means that you get DC via your converter when hooked up to shore power but zip when your not.
  • What voltage are you getting at the main DC circuit breaker when not connected to shoreline?
  • Welcome to the forum..........
    Any suggestions? Yes..Posting in the correct forum will get you the best results.
    Can't help you with your problem but once you move this to the forum it belongs in I'm sure you will get help.
