mikeleblanc413's avatar
Apr 22, 2014
No AC CURRENT to Winnebago Minnie Winnie
RE: 2000 Winnebago Minnie Winnie
I am at the COE park at Cochiti Lake near Santa Fe, NM
Early this morning the electricity cut off, but came back on shortly. I assumed it was the EMS PT30C doing its job. It cut off again and did not come back on. I checked the EMS at the electrical pedestal. All is normal. There are no error codes showing. The Winnebago handbook talks about a protective thermal breaker breaking the power to the converter section when overheating happens or when there is an obstruction of ventilation to the unit. The manual also indicates the thermal breaker will reset itself after a period of time. QUESTIONS: 1. Where do I find the converter section? 2. Is this a situation for an experienced Mobile Tech? 3. If so, can you recommend one in New Mexico or Arizona? THANKS.
  • I assume you know where the converter is, and you,ve reset the breakers? when I reset a breaker I flip it to off then reset. I
