tropical36
Apr 02, 2018Explorer
Ro646a wrote:
It is an Airpax Dimensions 2000 watt inverter. From what I have been able to ascertain, I'm pretty sure the problem is in the transfer switch.
Thanks
If you have some power, like with the ac's, then it sounds as if you'd lost just one leg and for whatever reason.
If there's 240/120vac power at the pedestal, then a meter at the transfer sw. should determine if it's indeed getting inside and beyond.
Metering the top and bottom of the main circuit breaker will tell you even more.
38,771 PostsLatest Activity: Apr 19, 2026
