dougrainer
May 16, 2023Nomad
"Most" Cruise control systems will NOT work if you have no Brake lights. So, once you find the Brake Light problem and it is fixed, odds are the cruise control will work. If you have a Ford Chassis, Brake Pedal Brake light switches are usually the problem if the fuses are OK. But, a defective switch will not cause the fuse to blow. Does the fuse blow ONLY when activating the Brake pedal? Or does the fuse blow when activating the Turn signals? Do you have amber or RED rear turn signal lights. Are you positive you have "released" the emergency 4 way flasher button? If still engaged and the lights do not flash that points to a defective 4 way flasher relay that may be the source of the short. There are 2 flashers. Turnsignal and 4 way flasher. Also which fuse/s blow? Turnsignals and Brake lights are on separate fuses. Doug
38,782 PostsLatest Activity: Sep 02, 2026
