tenbear
Jun 10, 2015Explorer
Mine has a solenoid (relay) that connects the chassis battery to the coach battery when the ignition is turned on. Some Class Cs also have a switch that actuates the solenoid for additional power for starting the engine. The solenoid failed and I replaced it and it has been fine since.
Use your multimeter to determine if the solenoid is bad if you have the same system.
38,766 PostsLatest Activity: Jan 10, 2026
