Old-Biscuit
Jan 12, 2015Explorer III
Not necessarily.
Fridge can be reset.
First "No Cooling" Fault Occurrence
Users can reset the controls by turning the refrigerator off then back on. The user resetting option can only be accomplished when the controls record the first "no cooling" ("n"/"no" "co") fault occurrence. The completion of a full cooling cycle will remove the recorded first "n"/"no" "co" fault from memory and returns the controls to normal monitoring operation.
Two Recorded "No Cooling" Fault Occurrences
If the controls detect two consecutive recorded "no cooling" faults , the "n"/"no" "co" fault code displays and the controls will lock out all heat sources (AC/LP/DC). The power board can then only be reset by an authorized service center after troubleshooting and testing cooling system operation.
HERE are reset methods
Some reasons for getting 'no co'
Poor ventilation.
Off-level operation.
DIrty burner.
Low AC voltage.
Cooling fan inoperative.
Improper installation.
Poor ventilation.
DIrty burner.
Low AC voltage.
