So, let's see. Pedestal Power is OK. All is ok when running on generator. But not when plugged into shore power. Therefore, must be the link between the park pedestal and the transfer switch. If the cord and the plug seem to check out ok, I'm thinking that your transfer switch may be the problem.
When you plug into to shore power and click on the breaker at the pedestal, you should hear your transfer switch click. If not, then either power is not getting to it, or the transfer switch bit-the-dust (It might be stuck in the generator position.)
