fltrker's avatar
fltrker
No electric
We have had the 03 Fleetwood Rev. Inside and plugged in to a 30amp 120 circuit for 2 months.
Getting ready to take off next Monday and noticed that the battery state on the indicator was not showing full charge. And the load meter is not showing anything. No lights on at all.
The xantrex is showing 30 amp in breaker amps and a <10 and 11.5 DC volts. And it is on invert.
Help.
  • Got power at the 30 amp plug?
    Any AC power anywhere?
    Does the inverter automatically charge, does it have to manually be set to charge?
    Blown fuse or tripped breaker in or out of the charger?
    How old are the batteries, when is the last time you checked water and connections?
  • Actually, most house batteries DO charge with the salesman switch in the off position. But easy to see how your works. Merely turn on the switch and see if the battery voltage comes up.
    Sounds like an issue with the charger section of the inverter/charger. Inverter switch should have no impact on charger function.
  • Was battery disconn. Switched turned off?
    Batteries do not charge in off position.
    Switch on invert? Invert makes 12 volts into 110 volt on a few outlets.
