ksg5000
Dec 09, 2015Explorer II
You have a CCI propane detector which operates a solenoid which controls the gas flow. Options -- 1) try and fix the propane detector - some have been successful using hair dryer blowing hot air through the detector slot 2) got to propane dealer and have them remove the solenoid 3) jump the solenoid forcing it open but understand that CCI solenoid operates at lower voltage so your 12 volt jump will end up overheating the solenoid - works in a pinch. Also - use the forum search feature because there is a post/reference to someone who fixes the old CCI propane detectors - worth a look.
38,769 PostsLatest Activity: Apr 03, 2026
