Harvey51
Apr 26, 2019Explorer
It looks like the engine battery isn’t getting charged. The voltage on the battery when it is supposed to be charging should tell if it is. When the engine is running the alternator should supply over 14 volts to the battery to push current into it. If it doesn’t then probably the alternator has failed.
As for other problems, I would connect a charger to the battery, then try lights, etc to see if they work when power is supplied from the charger.
