crawford wrote:
Maybe because the flow of electric is neg to pos if you check his post you will see it has many circuits and a ground cover many. Not like a fuse line a few in line it wouldn't jump all over the system. A ground and cover many and rust and cause a lost of problems.
While he has many circuits dead, on a Tiffin, the MAIN component that controls this is the Acc Solenoid, that Tiffin adds. RARE for that solenoid to lose Ground as it is mounted with 2 bolts to a metal Firewall and the only other cause would be the FUSE(POSITIVE) that sends the signal to that solenoid when the Ign Key is ON. 90% of the time the solenoid has failed on a Tiffin. Doug
