thomasroughton's avatar
Jun 06, 2015
No power to ignition
We have a 2004 class a itasca All of a sudden motorhome engine and dash won't turn on
When the ignition key is turned to on position horn , radio, windshield wipers work.
We have checked all fuses and everything has power except half the fuses under the dash.
Most things I read said it has to be a fusable link but can't find any to replace
Please help seems like it should just be a simple switch ugggggggg
    Sounds like an ignition sw and especially with chevy or workhorse and having a Saginaw steering column. If so, the sw. itself in mount on the column right side top and is actuated by a rod that is attached to the key tumbler.
  • If we're talking Ford, there is a relay located in the right wheel well and attached to the radiator frame. This relay among other things distributes battery power directly to the ignition and dash. The contacts are most likely the culprit.
    CAUTION, be sure to disconnect the battery prior to attempting to clean the contacts!
    This exact problem cost me $500.00 to diagnose the problem and clean those contacts. No problem since though.
  • STRAT here ,clean the battery lugs , check battery water , and follow the blk cable to its ground ,remove clean to bare metal. that way you know its got a good 12v.while your doing this have the battery load tested ,any auto store free.
  • On my F-53 there are fuses and circuit breakers in the front area of the coach. without more information it is hard to tell about yours. Most fusible links that I have seen are hard to tell between a normal wire and the fusible link.
    I would get a volt meter and start troubleshooting starting at the battery and keep going until you lose voltage. The battery cables can also be the problem. The items that you listed don't draw a lot of current and will work with a loose cable, but the starter is a high amperage draw item and sometimes will not work with a loose cable. JMO
