thomasroughton wrote:
We have a 2004 class a itasca All of a sudden motorhome engine and dash won't turn on
When the ignition key is turned to on position horn , radio, windshield wipers work.
We have checked all fuses and everything has power except half the fuses under the dash.
Most things I read said it has to be a fusable link but can't find any to replace
Please help seems like it should just be a simple switch ugggggggg
Sounds like an ignition sw and especially with chevy or workhorse and having a Saginaw steering column. If so, the sw. itself in mount on the column right side top and is actuated by a rod that is attached to the key tumbler.
