tomousecap wrote:
MamaGoose wrote:
Thanks, Bob. Where is the BCC box in your motorhome?
Not sure on your diesel. I believe it could be in or near the utility compartment. Friends diesel it is one compartment forward of the utility compartment leftside. The box is about 1ft. square and 4 or 5 inches deep. The front cover is held on by two toggle lever latches. The fuse socket they use tends to get loose and lose contact with the fuse terminals. Fuse may be fine or not. The BCC is the interface of the coach between most of the chassis and coach 12V circuits.
Ours is in a compartment on right side forward of the door, but ours is a gas coach.... Look around you will find it.... :)
Also be advised that if you call Fleetwood with your FIN number they will send you schematics and layouts for your coach free of charge. They can be very helpful in situations such as you have going on.
Good Luck with your efforts.
There is a panel of fuses in a compartment accessible from the outside. It is on the driver's side, front of the motorhome. Would that be what you call the BCC? The fuses there are all fine. DH said there is an inline fuse such as what you are describing outside of that panel. He checked that (disconnected it and reconnected it) and it appears to be fine. I guess next would be checking the wires leading up to the radio and see if there's power there. DH says he'll check the batteries again as well and make sure everything is connected properly.
