Gdlow
Apr 20, 2016Explorer
No power to jacks
I have a 05 National Dolphin. Has been in storage...getting ready to go home for summer and brought it to the house to load and no power to Jacks so I can't level it...I just changed the batteries i...
dougrainer wrote:
National connected the Leveling PUMP power thru the Coach Battery disconnect. That means the touchpad will light up, but the actual power to the pump will not be there if the Coach batteries are not turned on. When these type things come up---IF the Jacks worked prior to the battery change out, then when you changed the batteries you must have missed a battery connection or mis-wired a connection at the batteries. Doug
