jeffinpgh's avatar
jeffinpgh
No power to the column
I'm stumped... my 1986 c/g30 Chevy Fleetwood Arrow was running fine and all of a sudden (after I shut it off & wanted to start it 10 minutes later) I had no power. No power to the column. I turn the key in either direction & get nothing... no radio, no blower, no gauge movement, & no start. I replaced the ignition switch last night & still nothing. What would cause this... everything else works, headlights, brake lights, interior courtesy light...
Is there any relays/solenoids that powers up (keeps everything hot) everything BEFORE the key? What fuses should I be replacing if that may be the case & where are they? Would the coil (on top of the cap) do this if it fried itself? Alternator fried? Resistors? I just cant figure out why I'm not getting power.
Second question... can anyone explain in good detail, how would i go about creating a proper hot switch & start button combo to at least get this thing started so I can get it to a shop to be looked at further.
support much appreciated
