enblethen
Jan 19, 2019Nomad
Your water heater uses 12 volt for control and power to the circuit board,
You need to locate your 12 volt DC power distribution panel. Loction varies.
Slide could be a bad switch. Some slides run all the power for the motor through the switch rather then a relay.
