wa8yxm
Jan 19, 2019Explorer III
First: One thing both the slides and the water heater have in common is the 12 volt side of life.. Do lights and such work inside the RV?
The water heater uses 12 volts (Atwood) for all control and from the sounds of it you have an atwood. Subrurans.. It varies.. The slide runs and is also controleld by 12 volt.
Look to the fuse panel and then look to the control board.. Possibility of a replaceable fuse is low on the control board but not ZERO. ALso look for 12 volts at the control board connector. YOU WILL NEED a volt meter and the owner's manual to figure out which pin
There is an electrical connector. Usually on top of the tank inside.. I have to pull the tank to get at it. IT HAS NEVER come apart by accident.. on my atwood. But I'm not sayign it can not happen.
