AJR
Aug 22, 2016Explorer
My battery disconnect switch has a propensity to blow a 5A fuse located right at the solenoid/relay. From the way you say everything works on AC power. So does mine. When all AC is not available and that lovely fuse is blown. No 12V in the rig. I replace the fuse. Push the salesman disconnect switch and the light on the switch goes green. There are two fuses to the ??? relay. I just replace the bad one in the spring. Ya, replaced the wall switch, no joy. I have a bunch of 5A fuses now. Just use one a year.
