I have a 1996 Four Winds RV and am not getting any power inside. Fridge does not acknowledge any power when generator is running, or microwave, air, etc. I checked the breakers and none thrown, chang...
If the motor home doesn't have an automatic transfer switch, you have to plug your electrical supply cord which you use to plug into shore power, into an outlet, normally located around where the supply cord attaches to the motor home, to get power from the generator. I had a 1995 Four Winds which didn't have an automatic transfer switch.
