dallaswinn
Jun 23, 2014Explorer
no power???
I have a 1996 Four Winds RV and am not getting any power inside. Fridge does not acknowledge any power when generator is running, or microwave, air, etc. I checked the breakers and none thrown, chang...
dallaswinn wrote:Mich F wrote:
If the motor home doesn't have an automatic transfer switch, you have to plug your electrical supply cord which you use to plug into shore power, into an outlet, normally located around where the supply cord attaches to the motor home, to get power from the generator.
I had a 1995 Four Winds which didn't have an automatic transfer switch.
I think I know what you're talking about. The shoreline is already plugged into the RV, but you're saying that the other end, that normally plugs into the power source, also needs to be plugged into the RV? So, both ends will be plugged into the RV???
