Tinstar
Feb 15, 2021Explorer
No power
My 2002 Monaco Windsor is parked at home in 0 degree weather. I turned the heat pump on 40 degrees to keep it thawed. I just went out to check and I found no power. I've got 50 amps going to the m/...
dougrainer wrote:PastorCharlie wrote:
Why would a 2,000 watt inverter be wired into a heat pump circuit?
Its not. He just has 2 problems. Doug
