Tinstar
Feb 15, 2021Explorer
No power
My 2002 Monaco Windsor is parked at home in 0 degree weather. I turned the heat pump on 40 degrees to keep it thawed. I just went out to check and I found no power. I've got 50 amps going to the m/...
Tinstar wrote:dougrainer wrote:PastorCharlie wrote:
Why would a 2,000 watt inverter be wired into a heat pump circuit?
Its not. He just has 2 problems. Doug
Doug, That's what I was wondering. I couldn't imagine them being fed from the inverter but I didn't know. Does the a/c/heat-pump wire straight into the 120-volt circuit panel and it is not controlled by the inverter. I don't have aqua-hot. I have ran extension cords and am using small space heaters to keep water from freezing.
Sunday morning, I had about 15 power outages that were only out for about 3 to 5 seconds which may have caused the problems. Have you ever seen "welded contacts" as a fault?
