My 2002 Monaco Windsor is parked at home in 0 degree weather. I turned the heat pump on 40 degrees to keep it thawed. I just went out to check and I found no power. I've got 50 amps going to the m/...
Welded contacts is sometimes the result of rapid cycling of the electrical contactor. The 15 power outages certainly could have contributed to this situation. Contact damage can also occur with voltage that has gotten too low to properly hold the two contacts tight.
