dvleemin
Jul 27, 2017Explorer
hostage wrote:dvleemin wrote:1995brave wrote:
There are other drawings on the placement of each item. Download everything and then just start going though each drawing. In a few minutes you will understand what drawing has what. Save them, print them, and put them in the RV. If you get stuck, there are some people on here that know how to read them and can help.
Edit: Including me.
OK - here's the auto lights wiring diagram: http://www.winnebagoind.com/diagram/2005/05_s-ser_wire_148570.pdf
I'm struggling to figure where even to start.
that's not going to help you at all;;
your need one that shows power distribution centers such as relays and solenoids plus the one shown is mostly tail lites+ running lites etc does not show turn and brake system wirings
You never said but are your tail/running lights also out?? But Like said you need a full electrical drawings
OK thanks. Full electrical is here:
http://www.winnebagoind.com/diagram/2005/05_s40ad_70167474049.pdf
I wonder if there's a common ground that's bad, or maybe is there a common fuse?
38,780 PostsLatest Activity: Mar 30, 2014
