hostage
Jul 27, 2017Explorer
dvleemin wrote:hostage wrote:
but as asked all your park;;tail;;run lights all work?
Tail lights don't work - basically anything controlled by the headlight switch doesn't work (along with signal lights, docking lights, fog lights).
ok great need to have the whole story not 1/2 or 3/4 LOL;Iam agreeing with others where a master ground connection maybe bad
WHAT I WOULD DO RIGHT NOW is take a test light and see if u have power to the signal fuse and to the headlights;; IF you DO then run a dummy ground wire to one of the headlights and see what happens
that will be the proof in the pudding:: if NO power then its as I suggested a power supply relay solenoid bad somewhere
38,782 PostsLatest Activity: Sep 10, 2026
