rjstractor wrote:
Bordercollie wrote:
Make sure that you have a secure, out of the way, mounting for the spare wheel and tire. A loose 200 lb spare can do some damage in a sudden stop. In many situations it is not safe/doable for the ill-equipped owner to change RV tires.
Good point, but we are talking about E450 size tires, not semi trucks.  These spare tire/wheel assemblies are only about 50 pounds.  I would say that if one can handle changing a tire on a full size pickup then they should be able to change a class C motorhome tire without much difficulty.
Yep...the only difference is you need a little bigger jack...
