Lets hope this is your fix.
My Cummin's lost boost almost all at once. Same engine.
Barely could climb any grades.
There is a short (about 14") hose, about an inch in diameter that runs under the intake manifold from the front of the manifold to the air compressor. If you run your hand over the hose, you might find a hole, large enough to stick a finger in, in it right at the air compressor connect.
I put the same query on this same list and someone came back with the solution I gave to you. Even the exact location of the hole. Good luck, let me know if I'm right.
