JayMartin wrote:
I am now curious to learn the 10 reasons for not having a slide out. I was just assuming I was going to want the extra space but would like to understand the tradeoffs with those too.
Ron, what is the thing on your console and on top of the back up camera screen? (I know I'm wondering off topic; but it is my thread.:D )
Thanks again,
Jay
Hi Jay,
Here are the pros and cons to having a slide out (from my perspective)
Pros to having one or more slide outs
- a more open floor plan
- when it's time, the rig is easier to resell because people want slide outs
Cons to having one or more slide outs
- Each slide out costs $5600 MSRP more if buying a new special-order rig.
- Each slide out adds roughly 500 pounds to an already heavy load.
- The extra large hole in the wall reduces the overall structural integrity of the house.
- There is no significant header across the top of the opening. You run the risk of roof-sag, especially if a heavy a/c unit straddles the area.
- A slide out leaks in cold in cold climates, and heat in hot climates.
- A slide out lets in more noise in noise-ridden camping conditions.
- Spiders and other bugs are brought in when the slide out is brought in.
- Even with a topper, wind-driven rain will puddle on top of the slide out. Pull in a slide out with water on it and drive away, then watch the water fall in your house, maybe even on you.
- Slide outs rattle when driving your rig
- Slide outs can fail at the most inopportune times, when you are nowhere near a service center. You can't drive with a slide out sticking out.
- Slide outs take away from the travel experience by having a huge box inside the house.
- A slide out requires 3 or more inches on each sides and top, and have a slight step-up on the floor. This takes away linear wall space, interior over-head cabinet space, and head room.
- A couch inside a slide out is like sitting in a cavity. Pending the unit, it blocks viewing the TV.
- A dinette inside a slide out versus a no-slide dinette, will be significant tighter by the loss of that 3" x2 and the headroom. In our rig's case the sacrifice is worse yet due to the inability to utilize the transition wall as our no-slide dinette does as shown
HERE.
- When a slide out is extended, it makes accessing the outdoor storage underneath it very difficult.
- Slide outs require more maintenance to assure they work and seal as best as possible year after year.
- An appliance inside a slide out introduces the need for flexible plumbing lines, gas lines, or electrical lines (pending the appliance) further reducing reliability.
- A fridge inside a slide out has a less effective side-discharge chimney.
- With age and weathering, the seals will need replacing.
- Slide outs can get out of alignment to the house, causing progressive wear leading to worse problems to come.
Okay that was 20, not 10.
We special ordered our rig in 2007 specifically without a slide out and we LOVE it. We plan to own our rig for a minimum of 30 years so long term reliability was a very high priority for us. We also wanted a dinette and so we got a comfortable one that on occasion we turn into a bed for a guest. The larger dinette makes for a longer bed. We typically travel just the two of us and so we do extremely well without the optional dance floor that comes provided with a slide out.
The thing sitting on our center console, left side, is our Unified Brake Controller.
The thing sitting on top of our top-center rear view monitor is a ScanGauge-II.
