wa8yxm
Feb 14, 2015Explorer III
As I said, you need an extension pipe to extend the exhaust out to the Gen-Turi,,, Then use the Gen-turi on the slide.. That is how I would do it
Only problem is I often disconnect hot With the Genuine Gen-turi the pipe never gets so hot I can not hold it (One exception, full sun will make it hotter than the generator can) but you would need an OVE GLOVE to handle the extension pipe for a few minutes after disconnect.
You can also use flex pipe for the extension.
I would like to up-size the extension pipe a bit however.
