willald
Feb 16, 2015Explorer II
I have a Georgetown, and same predicament as the original poster - Generator and its exhaust is located underneath the living room slideout. Did not like it at first, but have since learned that it really is no big deal.
I researched this same subject also, considered fabricating something, or getting a Genturi and extension like Lantley discussed. Also seriously considered taking it to an exhaust shop and having them re-route the generator exhaust back a few feet so it'd come out just behind the slideout (this was my preferred solution, although we never did it).
Then, one time, when we were 'driveway camping' with the MH at some relative's house and needed to run the genny all night to have air conditioner, etc., I just said what the heck - we have a good CO detector, and there was not anybody outside around us that could be harmed. We just went ahead and ran the generator all night just like it is. No Genturi, no exhaust extensions, nothing.
I was very nervous about it that first night, but guess what? It worked just fine. CO detector never went off, was not a problem at all. Since then, we have done that several times, and it works just fine. Kids actually like it, say the generator's humming helps them go to sleep. That, and it combines two of their favorite things - camping, and staying at Grandparents house. :)
You definitely need to make sure your CO detector is in good working order. I also always make sure the rubber seals around the slideout are in good shape, too, whenever we do this (both things you should do, regardless).
Maybe before trying this, you might want to do a test - open the slideout, crank up the generator and let it run for a few hours. See if CO detector ever goes off inside the MH. If fumes are able to get in somewhere around the floor, better to know now rather than when out camping and you have to bail in the middle of the night. If CO detector does go off or you smell exhaust inside, then you can look at maybe doing some of the exhaust ideas being discussed here.
You may well just find like I did, though, that this really is not as big an issue as it may seem.
If you do decide to do something about this, my preference would be to have an exhaust shop re-route the exhaust away from the slide, at which point you can either use a Genturi or fabricate something of your own like it.
