k9-keno
Dec 03, 2015Explorer
Jordan I just bought the 2007 Damon Daybreak with the bunks. It is the Ford V10 with 12,100 miles on it. The drive is great on it. I will warn you as I figured out check under both slides for floor rot. These units as well as many built around that time didn't put a drip edge on the slides so the water goes under and wicks in the screw holes and then you have rot. On the bunk slide just tap the black paper looking stuff on outside bottom look for soft spots. On the big living room slide look at bottom on the outside wall under slide. Inside I just may upgrade TV's to lighter flat panel Tv's. Any questions let me know!! And good luck
38,782 PostsLatest Activity: Sep 10, 2026
