Does it cool better if using AC element?
Poor cooling in LP....
When was last time you cleaned/serviced the burner area?
Dirty/obstructed burner slots will result in poor cooling
Low propane pressure will also....11"WC
Fridge in slide?
Fans should be running based on 'condenser fin temps'
Condenser is at top of fridge.....fan sensor/t-stat is attached to far right fin
Closes at 130*F condenser fin temp to start fans/opens at 115*F
Thermistor....
Temp sensor inside fridge S/B be attached to 2nd fin from right
