supercub's avatar
supercub
Norcold 1200 won't turn on ??
Frig has been working fine. When I got up this morning it wasn't working, tried turning it on and nothing. I took a magnet and ran it across the little box outside and still nothing. The little box, can't remember what it's called but I believe it's a safety device, has a red light and it was on steady. Looking on trouble shooting suggestions, It's a Norcold 1200LRIM. Thanks
  • Well I had my motorhome washed at a truck wash yesterday. They used a lot of water, so I'm thinking that's the problem. I haven't had any success resetting the switch with a magnet. How do you do it manually?
  • I have a Norcold 1200RIM. Every time I drove thru a rainstorm, that red light would come on and the switch would activate and shut down the fridge. I would have to get the hair dryer and dry off the switch and then take a magnet and reset it.
    Then came the day it would not reset. I was on my way home from a 2 month summer trip, the weather was hot, so I decided to just by pass the switch so I could get the fridge working again. I of course, can not recommend you do this, but it is a simple process and it can get you working again.
    When I got home I ordered the 110 volt HVAC cooling unit from JC refrigeration. No more fridge problems and the Norcold works like a residential unit.
  • supercub wrote:
    Will the red light go out immediately when you reset with the magnet?
    YES!
    It is a 'Reed Switch' and can take several seconds to reset
    IF magnet does NOT reset it....Light go out...then you can remove the cover and manually reset the reed switch
  • Will the red light go out immediately when you reset with the magnet?
  • That RED light on SOLID (Recall Box) indicates the Stack High-High Temp Sensor has tripped (700*F)
    When tripped ALL DC to fridge shuts off
    So either the cooling unit has a 'Leak' (check for any yellowish residue in/near burner area or ANY place on tubing.
    THAT means DEAD
    No signs of leaking......
    Has it Rained?
    Have you washed the RV recently?
    Water can 'short' the Recall Box little circuit board/sensor wiring etc
    Hair Dryer to rid the box/wiring of moisture then Tilt Box more downward so it is less susceptible to moisture
    Could just be a faulty Recall Box circuit board....most current version is 'E'
    * look thru small opening on front of Recall Box and check which version you have ---if not 'E' contact Norcold for upgrade
    IF not an 'E' the lower versions may/may not reset using the magnet
    Strong Magnet held on face of Recall Box near top and then slowly move back/forth until you hear a CLICK and RED Light goes OUT
