TC_Z's avatar
TC_Z
Norcold 121 Series Condenser Fan Noise
We have a 4 door Norcold 121 Series refrigerator. Now and then we have started hearing a whiring bearing noise from the back of the refrigerator. I suspect one or both of the condenser fin cooling fans are wearing out. The refrigerator is 9 years old. I cannot see the fans from the exterior refrigerator access panel, there's all sorts of pipes in the way. It is very tight there. I climbed on the roof and took off the refrigerator vent cap. I can see the condenser fins but not the fans.
Not sure but bet to replace these fans would have to remove the entire refrigerator. That would be a pain.
Has anyone else had this problem? Any suggestions or ideas how to repair?
  • Get Ball bearing fans. Replace the Fan Tstat also. You must pull a 1200 series to replace the fans and tstat. Doug
  • Disconnect gas and power 12volt and 110. Disconnect water to ice maker .. Unscrew around faceplate ( covers come off) and pull out .. Have support to hold it at the right level, replace the fans .. I'd add and extra for 3 .. Then reverse What could be complicated ? :-)
    DID you really mean 1210???( I think) Its very easy to move the fridge out.The fans are screwed to the back of the fridge about a foot below the condenser
