Kaz
May 11, 2016Explorer
ct78barnes wrote:
Did any others get a post card for this suite and fill it out. Mine was on the list and I had to go on line to send in the form. Is this for real or not.
We got one. I followed the link and spent some time reading the pleadings. It certainly looks legit. The settlement calls for a $36 million fund to be distributed in installments to eligible claimants, less administrative expenses and attorneys fees. The actual amount distributed will depend on those fees and expenses, as well as the number of claimants. (Like most such class actions, the attorney's fees can be substantial, but are limited by the express terms of the agreement.) The share each claimant gets is determined by the type of unit and its replacement/repair cost. Also, the settlement provides for a three-year extended/add-on warranty to cover parts and labor for any claimant whose unit fails due to a leak during that period. Each of the claimants will also receive a warning notice that reads as follows:
WARNING:
Norcold has recalled all Model 1200 series refrigerators manufactured prior to October 6, 2010. The purpose of the recall is to remedy a safety related defect by installing a High Temperature Sensor (HTS). Therefore, if you own such a refrigerator and have not had the HTS installed, you should turn off your refrigerator immediately and call the Norcold Recall Department at (800) 767.9101 to make arrangements to have the HTS installed at no charge to you.
If the HTS has been installed and it trips (red light continuously lit), the Refrigerator must always be brought in and checked by a trained technician. It is imperative that you never bypass the HTS.
Norcold had previously recalled 6 cubic foot and 8 cubic foot refrigerators with serial numbers1038000 to 1099000. If you own one of these refrigerators and you have not had the original cooling unit replaced you should immediately turn off your refrigerator and contact the Norcold Recall Department at 800.767.9101 to make arrangements to have your original cooling unit replaced
at no cost to you.
It is essential that if you are experiencing cooling performance issues with your Refrigerator you immediately take it to a dealer and have it checked by a trained Technician.
FAILURE TO FOLLOW THESE INSTRUCTIONS CAN RESULT IN FIRE, CAUSING PROPERTY DAMAGE, INJURY OR DEATH.
I haven't signed up yet (I'm still working my way through the pleadings), but I'm pretty sure I will.
Skip
38,782 PostsLatest Activity: Aug 31, 2026
