dougrainer
Oct 16, 2016Nomad
usersmanual wrote:I know this question is a couple of years old but our fridge started showing that error code after we were in a nasty, blowing storm up on the Oregon coast. I just have a couple of questions. 1. Should the refrigerator be unplugged from power when you reset the switch and 2. How strong of a magnet? Thanks!
Water should have nothing to do with it.there pretty well sealed
I have done a few resets - its takes a fairly strong magnet
If it does not start to cool normally right away it may have a cooling unit problem so pay attention
Well, I have taken a few apart and found corrosion on the board. So, YES, water intrusion is a likely cause. IF you research this forum, you will see that a lot of the posted failures all have one thing in common---After power washing or a heavy rain they had the failure. Also, there are 2 places the recall box is installed. The recall kit if part of the recall was clipped on the coil. OEM units built after the recall are mounted on the wall of the refer. If not clipped in the correct place, the water may get into it. Doug
38,783 PostsLatest Activity: Sep 24, 2026
