- Road_RunnersExplorer
captpar wrote:
Fridge fine yesterday,today flashing L1 OP and not woking,how do I fix this?
I found the information below by doing a google search. I don't know if this the final answer, but it looks that your code means you have something that you will have to take and get fixed.
"Norcold Book Fault Code shows "LI" "oP" meaning High Temp Limit Switch is open, not owner serviceable.
If you've had the most recent Norcold recall installed, go out and remove the external cover from the rear of the frig and see if the red LED is lit on the new high temp controller (black box). if so you need a new one installed. this is a very common problem, especially with the earlier versions of these black boxes used in the latest recall program. "
38,766 PostsLatest Activity: Jan 10, 2026
