Executive45
Nov 03, 2012Explorer III
Remove the outside vent cover. Inside, you'll see a black plastic cover with a bunch of wires in it. This cover must be removed..3/4 1/4" screws. Inside this box are two fuses. One looks like the old car fuses and the other is the typical mini fuses found in today's cars. The old car fuse is actually the 120V fuse and the mini fuse is your 12V fuse. It should be a 5amp fuse. Replace that fuse and reassemble. Then try the fridge...let us know if that doesn't fix it....Dennis
BTW...before removing any wires, take a picture so you know where they all go.
The lower left corner is your 120V plug in.
Next to that you will see a black wire with a smaller black wire and next to that is the same configuration but will be white.
You will see a yellow wire, that's your 12V supply.
Next to the yellow wire is a white wire going to your LP switch.
Below those is a large white wire. That's your ground.
Next to the white wire is a smaller white wire that goes to the other side of the LP switch.
Finally, there is a large orange wire. Use caution with that wire as it feeds the capacitor and could still hold a charge.
Hope this helps...Dennis
38,782 PostsLatest Activity: Sep 01, 2026
