2ndhom's avatar
2ndhom
Norcold Fridge Shelves ....
It's time to give the double door fridge a good cleaning. Thought the 3 grated shelves would just slide out. Not!!! I see two verticle, one on each side white trim material held on by 3 screws. Before I begin taking things apart, thought I'd ask the professionals .... "is this the way the shelves come out, by removing the 2 strips first"?
Thanks much!!
:h
  • 2ndhom wrote:
    Yep, the 3 screws on each side were removed easily. They did not strip inside the plastic housing of the fridge. Wasn't sure if maybe a nut on the backside would slip down inside. No nut .... just me!! The shelves were removed easily for cleaning + inside was easier to wipe down & around.
    Thanks!!
    You're most welcome, have fun and travel safe...:)
  • Yep, the 3 screws on each side were removed easily. They did not strip inside the plastic housing of the fridge. Wasn't sure if maybe a nut on the backside would slip down inside. No nut .... just me!! The shelves were removed easily for cleaning + inside was easier to wipe down & around.
    Thanks!!
  • am I wrong,, because something waaay back in my mind tells me that dometic is the best rv fridge but I don't remember why.
    Any suggestions on preference from anyone?
    Thanks much!!
    :h
    YES, I have the same type as yours and you need to remove the screws from the trim pieces on each side, then remove the trim pieces so you can remove the shelving.
    Good luck and have fun..
