2ndhom wrote:
It's time to give the double door fridge a good cleaning. Thought the 3 grated shelves would just slide out. Not!!! I see two verticle, one on each side white trim material held on by 3 screws. Before I begin taking things apart, thought I'd ask the professionals .... "is this the way the shelves come out, by removing the 2 strips first"?
Thanks much!!
:h
YES, I have the same type as yours and you need to remove the screws from the trim pieces on each side, then remove the trim pieces so you can remove the shelving.
Good luck and have fun..
