Hi all I have a norcold fridge n811,power board 628661,works fine on electric but when you try to light on gas both lights on the control panel flash,you check outside behind the panel you can hear t...
Contact Dinosaur Boards and talk to them before buying a control board. https://www.dinosaurelectronics.com/Cust_Service.htm They won't sell you a board unless you need it after sharing your problem with them. They'll give you troubleshooting suggestions to help you determine the source of your problem.
